View unanswered posts | View active topics It is currently 05 Nov 2026, 22:01
Post new topic
Reply to topic
 [ 1 post ]
Author Message
 Post subject: Cannot Patch/Login DNS Fix (Outdated)
PostPosted: 26 Oct 2007, 07:43
Offline
Site Administrator
Site Administrator
User avatar
18 Feb 2004
1487
Viborg, DK
Homeshard:
Drachenfels
Played Since:
The Second Age
NOTE: This fix is no longer valid!
i will explain this for those not so computer literate..
For ALL
1. Open My computer
2. Open C:
3. Open Windows Folder
4. Open system32 Folder
5. Open drivers Folder
6. Open etc Folder
7. Double click file "hosts" and open it with notepad
now you have in notepad something similar to this (in your own language):
Code:
# Copyright (c) 1993-1999 Microsoft Corp.
# Dette er HOSTS-eksempelfilen, der bruges af Microsoft TCP/IP til Windows.
# Denne fil indeholder IP-adressetilknytninger til v?rtsnavne. Du b?r ikke
# angive flere end en post pr. linje. IP-adressen skal placeres i den f?rste
# kolonne efterfulgt af det tilsvarende v?rtsnavn.
# IP-adressen og v?rtsnavnet kan adskilles af mindst ?t mellemrum.
# Kommentarer (som disse) kan inds?ttes p? individuelle linjer eller efter-
# f?lge computernavn. Kommentarer skal anf?res med nummertegn '#'.
# Eksempel:
#      102.54.94.97     rhino.acme.com          # kildeserver
#       38.25.63.10     x.acme.com              # x-klientv?rt
127.0.0.1       localhost
Below
Code:
127.0.0.1 localhost
Add:
Code:
159.153.197.91 compassion.owo.com
159.153.156.150 drachenfels.owo.com
159.153.196.41 login.owo.com
For WinXP/Win2K
save and close
Done!
For Vista/Win7
1. Save in documents folder.
2. uncheck "Hide extention for known file types" (last part of filename) in folder option in control panel its a suboption of "Apperance and personalization"
3. find the hosts.txt file in documents folder.
4. remove ".txt" from file name so its only named "hosts" without an extention.
5. copy it to previously stated folder and overwrite it.
Done!
this way it bypass the dns servers and tell the computer that if internet requires the adress go to ip in front :)
it helps for some issues but not all, unfortunetly...
_________________
Quick Links: Imbuing Calculator | Transfer Central | In-Game Auctions | Contact
Top
 Profile
Display posts from previous:  Sort by
Post new topic
Reply to topic
 [ 1 post ]
Who is online
Users browsing this forum: No registered users and 13 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
[ Time : 0.089s | 16 Queries | GZIP : On ]
