View unanswered posts | View active topics It is currently 02 Nov 2026, 07:29
Post new topic
Reply to topic
 [ 3 posts ]
Author Message
 Post subject: Login Issues
PostPosted: 28 Mar 2013, 07:43
Offline
Site Administrator
Site Administrator
User avatar
18 Feb 2004
1487
Viborg, DK
Homeshard:
Drachenfels
Played Since:
The Second Age
Greetings Citizens
Since the maintenance last night, some people are still having issues with connecting this morning.
This is due to the login server changed IP address in the process.
EDIT: First of all, if your pc was on during the whole thing, it is suggested to restart it, if that don't work, read on.
If your PC are not able to connect there are 3 potential workarounds. They are:
Step 1.
Power of your router/modem, wait about 30 seconds, then power it back on, if problem persist continue to step 2.
Step 2.
In "Run" (XP), or Search field in start menu (Win7), type "CMD" and run it (it is command prompt). in it type:
Code:
ipconfig /flushdns
If problem persist continue to step 3.
Step 3.
This is a temporary solution and you will need to remove this entry if you experience problems in future (when the ip change again).
Locate c:\windows\system32\drivers\etc\hosts and open it in notepad
On a blank line put the following
Code:
107.23.176.74 login.ultimaonline.com
Without a # infront.
Save file as you found it, some versions of windows might want to play tricks on you and add .txt, is important it is saved without any extension.
Safe Travels
-The Knuckleheads
_________________
Quick Links: Imbuing Calculator | Transfer Central | In-Game Auctions | Contact
Top
 Profile
 Post subject: Re: Login Issues
PostPosted: 28 Mar 2013, 19:38
Offline
Valued Member
Valued Member
User avatar
14 Jun 2011
103
Mainz, Germany
Homeshard:
Drachenfels
Played Since:
The Second Age
Thanks alot - you are a great help!
_________________
I don´t believe in Tangle - it doesn´t exist!
Top
 Profile
PostPosted: 28 Mar 2013, 21:51
Offline
Forum Newbie
Forum Newbie
27 Mar 2013
1
Homeshard:
Drachenfels
Played Since:
The Second Age
Thanks a lot. :)
Funny thing is the hosts entry worked flawlessly this morning...now after the patch I'm locked out again xD Cuuurse you patch
Top
 Profile
Display posts from previous:  Sort by
Post new topic
Reply to topic
 [ 3 posts ]
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
[ Time : 0.069s | 18 Queries | GZIP : On ]
